Hello!
A great deal depends on the type of transistor used, and the 2N2222 is not the best choice.
I have achieved good results using KT606 and KT610 transistors, though it is unlikely that these will be available to you.
For resistor R1, you should use a multi-turn potentiometer, as the adjustment of the signal level coming from the synthesizer (or generator) requires very fine, precise control.
Any "Micro" transceiver—or a variation thereof—is not a device with a highly sensitive receiver; therefore, you need antennas designed for specific frequency bands.
A 10-meter length of wire is insufficient for the 40-meter band and will have very low efficiency.
While you could certainly tune a 10-meter wire antenna to resonance, it would remain inefficient—especially when it comes to receiving stations using a "Micro" transceiver.
